tranny locked up
Roger
07-26-2003 08:55:09
my transmission on 8n is locked up can run engine and roll wheels but bogs down when u try to let out clutch.
raytasch
07-26-2003 16:23:58
 Re: tranny locked up in reply to Roger, 07-26-2003 08:55:09
Don't loose the shift detent ball or spring when you remove the top plate.
ray
Dell (WA)
07-26-2003 11:09:13
Roger..... .....ya gotts yer tranny in 2-gears at the same time. 8N's have a removeable tranny shifter top plate. But there are some spring loaded parts that can go sproing so becarefull in removeing the top plate.
Its not rocket science, but close to brain surgery (grin). Get out your I&T FO-4 manual ($27 cheap). There is probably some worn/bent part on the shifter plates that ONLY YOU can find by inspection. Generally speaking, you haven't damaged the tranny gears, just the shifter plates..... ....Dell
Roger
07-26-2003 11:41:53
 Re: Re: tranny locked up in reply to Dell (WA), 07-26-2003 11:09:13
opened it up, 2nd 3rd shifter was between gears 1st 4th was engaged. freed both closed it up still jammed. didn't see anything else.
Dell (WA)
07-26-2003 11:59:25
 Re: Re: Re: tranny locked up in reply to Roger, 07-26-2003 11:41:53
Roger..... ...ya didn't look deep enuff..... If'n yer still locked up, then ya gotts something stuck between some gear teeth. You are your OWN INSPECTOR.
Most likely, you'll haffta drain yer 5 gals of hydro-tranny oil to be able to see under all that oil. Drain yer square diffy plug first 'cuz it'll pee innna buckett with some amount of accuracy. You might NOT need to finish draining the 3" tranny plug, but I would just to make certain that you don't have any chunks down at the bottom of the tranny case..... .....Dell
Roger (La.)
07-26-2003 12:05:54
 Re: Re: Re: Re: tranny locked up in reply to Dell (WA), 07-26-2003 11:59:25
thanks guys, I'll have to dig deeper when the rain stops.
Tom (MI)
07-26-2003 09:42:51
Will the tractor roll with the clutch pedal down?
Roger
07-26-2003 10:53:11
 Re: Re: tranny locked up in reply to Tom (MI), 07-26-2003 09:42:51
didn't have anybody there to help roll and hold clutch pedal.
Tom (MI)
07-26-2003 11:10:27
 Re: Re: Re: tranny locked up in reply to Roger, 07-26-2003 10:53:11
Can you let out the clutch pedal in neutral without it stalling? If so, the tranny isn't locked up. Make sure your PTO is disengaged.
Roger
07-26-2003 11:34:20
 Re: Re: Re: Re: tranny locked up in reply to Tom (MI), 07-26-2003 11:10:27
motor stalls when clutch is let out in neutral or any gear. pto is disengaged and turns freely.
Tom (MI)
07-26-2003 11:39:42
 Re: Re: Re: Re: Re: tranny locked up in reply to Roger, 07-26-2003 11:34:20
Like Dell said, you're in more than one gear at the same time. Take the cover, and with a pry bar, (and very GENTLE persuasion) pull all the forks into neutral. Then look into what caused it to happen.
