No Spark
Randy(Ohio)
07-26-2003 11:10:00
I have an 8n with side mount dist.,12 volt conversion.It was running fine then quit and now no sparkies.I have replaced the cap,rotor,points,condenser,wires and plugs.Made new grounding wire for distributor and still no luck.Any suggestions?Tkanks for any help. Randy
Randy(Ohio)
07-26-2003 13:13:24
 Re: No Spark in reply to Randy(Ohio), 07-26-2003 11:10:00
Thanks for all the help.It is running like a champ again.Dell it was the insulator on the pass thru bolt.Thanks ALOT Randy
Mike OH
07-26-2003 11:22:39
Couple more things out side of a bad coil is the key switch. (Easy to check by jumpering around it), and resistor, if you used one in making the conversion. Also check to see if all wires are making good connections and are clean. Good luck.
Tom (MI)
07-26-2003 11:25:25
 Re: Re: No Spark in reply to Mike OH, 07-26-2003 11:22:39
That's how I found out my switch was bad, ran a wire from the battery straight to the coil, had all kinds of spark then.
Tom
Randy(Ohio)
07-26-2003 11:34:46
 Re: Re: Re: No Spark in reply to Tom (MI), 07-26-2003 11:25:25
Has new resistor,different coil.No luck on wire from battery to coil. Randy
Mike OH
07-26-2003 11:44:54
 Re: Re: Re: Re: No Spark in reply to Randy(Ohio), 07-26-2003 11:34:46
May be time to get the old volt meter or 12v test light out and check to see if you have voltage at the coil - check with points open and closed.
Randy(Ohio)
07-26-2003 11:51:55
 Re: Re: Re: Re: Re: No Spark in reply to Mike OH, 07-26-2003 11:44:54
Used test light have juice at coil but nothing at the points opened or closed.
Dell (WA)
07-26-2003 12:07:57
 Re: Re: Re: Re: Re: Re: No Spark in reply to Randy(Ohio), 07-26-2003 11:51:55
Randy..... ...when you say you have juice at the coil but none at the points, are you saying that you have juice at the coil ignition switch side of the 2-terminal roundcan coil? And that you are saying that at the points side of the roundcan coil you have NO JUICE? That sounds like an OPEN PRIMARY coil winding. To make certain that you don't have an undisclosed ground on the points side, disconnect the coil wire at the distributor feedthru terminal. IF STILL NO JUICE, then coil is bad and need replacing. IF JUICE, then your distributor feedthru terminal is shorted to ground and the feedthru insulator needs replacing..... .Dell
Fast Ed Ohio
07-26-2003 22:19:06
 Re: Re: Re: Re: Re: Re: Re: No Spark in reply to Dell (WA), 07-26-2003 12:07:57
Yea, I was going to say a bad coil, do what Dell says to prove your problem . Iv been wrong before .
Mike OH
07-26-2003 12:02:28
Suspect you have a ground somewhere in this area. Make sure the wire going into the distrubutor from the coil is not being grounded at the connection.
Randy(Ohio)
07-26-2003 12:07:13
 Re: Re: Re: Re: Re: Re: Re: No Spark in reply to Mike OH, 07-26-2003 12:02:28
Made new wires for the coil to dist. and points to dist.Used rubber to insulate bolt from dist. Randy
Tom (MI)
07-26-2003 11:58:17
did you put a new coil on? If so, did you stretch the coil spring out a bit? Had to do that with mine.
Roger '40 9n
07-26-2003 12:07:18
 Re: Re: Re: Re: Re: Re: Re: No Spark in reply to Tom (MI), 07-26-2003 11:58:17
"did you stretch the coil spring out a bit?"
Question: How do you stretch the coil spring on a
sidemount (round can) coil?
Roger in Michigan.
you don't . . . Dell
07-26-2003 12:12:10
 Re: Re: Re: Re: Re: Re: Re: Re: No Spark in reply to Roger '40 9n, 07-26-2003 12:07:18
Randy..... ...sometime advisors miss-read the question, sometimes the post is un-clear, OBVIOUSLY, there is NO SPRINGTHINGY with a 2-terminal roundcan ignition coil..... ...Dell
Tom (MI)
07-26-2003 12:09:51
Forgot it was side-mount.
