Starts but won't keep running
RJ Ramos
07-29-2003 12:06:25
My 8N starts good and will run until it's put into gear. Then starts to cut out and finally shuts down. (just for info) I can keep it running if I use the choke in and out rapidly. Want to check the Carb Filter just don't recognize it to check it. Need help!
Evil Steve
07-29-2003 12:44:19
 Re: Starts but won't keep running in reply to RJ Ramos, 07-29-2003 12:06:25
If you are SURE your points are properly gapped and in good shape so that you are getting nice whitiesh/blue spark, then:
1) One or all three fuel screens are plugged (one is a 1 1/2" little tube screen that sticks up into gas tank from top of fuel bowl assembly, one is flat screen in fuel bowl dorectly over glass bowl, one is small tube in the elbow that connects fuel line to carb, and/or
2) manifold gasket leak.
