Front Wheel interchange?
Paul
07-30-2003 07:12:44
Can someone tell me the bolt pattern, or what readily available car wheel will work on an 8n? I'm not close to the tractor, right now, but I am close to a junk yard, and I need to replace the fronts on both sides anyway. I always thought those narrow fronts are just too much hassle in mud and such. Thanks very much.
Paul
Dana
07-30-2003 09:59:19
 Re: Front Wheel interchange? in reply to Paul, 07-30-2003 07:12:44
I think the wheels from a Chevy 4x4 1/2 ton truck (6 lug) will fit.
no sir==bj/8n/mt
07-30-2003 10:34:14
 Re: Re: Front Wheel interchange? in reply to Dana, 07-30-2003 09:59:19
Six lug chevy pickup rims have a different bolt pattern. You can make them fit by redrilling the hubs but unless you have a lathe to turn the hubs in you are likely buying trouble and even if you did I wouldn't go to that trouble again. Been there done that.
The wheels he needs have a six inch circle with a four point six inch pilot.
Your mileage may vary
Greg G
07-30-2003 20:20:42
 Re: Re: Re: Front Wheel interchange? in reply to no sir==bj/8n/mt, 07-30-2003 10:34:14
What year Ford car can you replace the tractor hubs with and then use the car rims? I have herd this being done but have never been told exactly what year hubs one would have to use.
Greg G
don't know==bj/8n/mt
07-31-2003 05:19:27
 Re: Re: Re: Re: Front Wheel interchange? in reply to Greg G, 07-30-2003 20:20:42
I know of no car wheel that fits an 8n hub. So far as I know these are impelement specific. Lots of them around though since they fit a lot of ag applications.
