Order Ford 9N Parts Online
9N wont start when hot
plowboy
07-30-2003 19:32:48
I finally got the 9N started;
New points, coil, rotor, silinoid, resistor
and a 12volt battery, everything else is 6volt
it started ran for a hour pulling a box.
When I turned it off to putt gass in it would not start up agin. No spark. Coil feels pretty hot.
Is this due to 12volt battery?
dale
07-31-2003 10:49:34
 Re: 9N wont start when hot in reply to plowboy, 07-30-2003 19:32:48
the same thing happens with mine, only I've never messed with changing to 12 volt. any suggestions
Jim WI
07-31-2003 10:40:45
Exactly the right symptoms for a 6V system that's running at 12V. Change the battery! (and probably the coil -- I doubt it's much good now)
wheelman
07-30-2003 21:18:31
check to see if you have a 12 volt coil w/ a 12 volt system or is it a 6 volt coil w/ a12 volt sys
