OT - Trailer weight and hauling a Massey Ferguson
PJ
08-06-2003 14:32:45
Hello,
I'm thinking about buying a 5ft Massey Ferguson bush hog. The bush hog is about 275 miles (just happens that we're going where the bush hog is this weekend anyway) away and I'm planning to use my wife's 2000 Ford Explorer to pull the bush hog back on my trailer. My question, does anyone know how much a standard 16ft, dual axle trailer and bush hog combination might weigh? The trailer has the two standard 3500 lb axles. I was thinking that the trailer might weigh 1000 lbs and the used bush hog might weigh 650 lbs at most. Can my Explorer handle this load, I've never towed with it? The Explorer is a SOHC V-6 automatic with 3.55 rear end.
Thanks.
souNdguy
08-07-2003 07:38:19
 Re: OT - Trailer weight and hauling a Massey Fergu in reply to PJ, 08-06-2003 14:32:45
My tandem axle 16' trailer weighs right at 1800lbs. The bushhog might weigh between 400-700 lbs... I'm guessing you won't nitice the busshog on the trailer... in otherwords it will probably pull the same going up and back.
If that explorer has a class III receiver it should do 500/5000 toung/haul weight. I pulled a horse trailer ( 1650# ) and 1 horse (~1000#) on my 99 v-6 ranger. Was the samll 3.0 v-6.. didn't pull well, and the rear end had to light of suspension... your explorer should have a slightly stiffer rear end, and has a bit bigger engine ( 4.0 right? ).
should be good to go.
Be safe.. chain your loads, and if you don't have electric brakes keep in mind that you have about 2300# behind you extra. I had an electric brake controller on my ranger, and that is what made the difference. Now all my tow vehicles have one. ( I traded the ranger for a 'real' truck, a dodge ram. Much easier pull now with that 5.9l engine..
Soundguy
FC
08-07-2003 06:28:02
You are pretty close on the weight. Probably not much over 1500 lbs and definetely not over 2000 lbs. Should be no problem towing it. Make sure your load is fairly well centered. I've had problems if I set the load too far back on the trailer and takes weight off the back of the vehicle causing handling problems.
RoN of ohio
08-06-2003 19:46:52
I don't know what the bush hog weighs, but sounds like your trailer is like mine..1140lbs. Just my Honest opinion..Ron
Tom (MI)
08-06-2003 14:40:22
With that little bush hog and a tandem axle trailer, you won't notice it's back there. Be carefull you don't forget you're draggin a wagon!! =)
Tom
