orc half hole short
P.W.(WI)
08-07-2003 20:02:10
First post but have been following site for some time. Putting A orc on 9N but will not go on far enough to get roll pin in by 1/2 hole (hits pto housing with big diameter of orc.) I'm tool & die maker and am considering turning the big diameter back enough to make it work. Looks strong enough & I think this will only lengthen small diameter and pto will enter further (plenty of room for both). I Know it's probably pto problem but I don't want to tackle that.You all helped me alot in the past and I value your in put. What do you think. Thanks!
P.W. ( WI)
08-08-2003 03:32:18
 Re: orc half hole short in reply to P.W.(WI), 08-07-2003 20:02:10
Thanks for Quick response folks. I'm takin her in for surgery this mornin. As usual great advise!
9NKen
08-07-2003 23:47:52
Hi P.W.
I had to turn down my ORC to get it to fit my '41. I've since logged many hours brush hogging with no ill affects.
Ken
Mike
08-07-2003 20:27:23
P.W..
Rather than take the trouble to pull the shaft to put it in a lathe, I think I would have the PTO in gear with the tractor running and use my die grinder with a cut off wheel lightly until I have the shoulder down to where the ORC will fit, good luck.
Mike
Dell (WA)
08-07-2003 20:12:19
PW..... ...yes, you have accurately diagnosed your ORC problem. Early 9N's 1 1/8 PTO's have slight lip of PTO support shell and the ORC won't quite fit. The modern 1 3/8 bolt-in replacement PTO doesn't have that problem. Since you have access to a lathe, should be NO PROBLEM for you to cut your ORC down a schoshe (or RCH)..... ...Dell
Terry G
08-08-2003 13:02:47
 Re: Re: orc half hole short in reply to Dell (WA), 08-07-2003 20:12:19
Dell, You are only the second person I have ever heard use the word "schoshe". The other person was measuring engine timing in schoshes. Just how much is a schoshe? I always assumed it was the exact measurement you needed when inches or millimeters or degrees just wouldn't cut it.
Terry
