Valve adjustment
R.M.
01-12-2001 22:08:25
I have a 1949 8n that I have never adjusted the valves. The tractor runs good, but I was wondering how often the valves should be adjusted and the procedure to go through to make sure that the valve clearence is open to guage.How do you tell the exhaust from the intake. I understand that the Intake are set to.011 and the exhaust are set to.015. Any tips...Thanks
Nogrimace
01-14-2001 13:52:49
 Re: valve adjustment in reply to R.M., 01-12-2001 22:08:25
Zane is correct, if it ain't broke don't play with it, otherwise something will break.
Look at your intake and exhaust manifold, the ones coming from your carb are the intakes, the ones leaving the engine to the exhaust is the others.
ZANE
01-13-2001 04:38:51
Old addage #1 - "If it ain't broke don't fix it!"
