Reid..... ...you write..... ."P1 (on ALT)goes to my ACC(on IGN SW), BAT(on ALT) goes to ING(on IGN SW), P2(on ALT) goes to BAT (on IGN SW)" First off, ignition switches can't handle the POWER out of the alternator without burning up. So when you write ...." BAT(on ALT) goes to ING(on IGN SW)"..... that scares me..... Because your alternator is at least 50 amps output..... .and "ING" is usually ignition switch OUTPUT and goes to the ignition coil, not BATT input (from alternator) Secondly, you write....."P2(on ALT) goes to BAT (on IGN SW).....usually P2 is connected by short wire to alternator BATT STUD. The only thing that makes sense is..... .you write..... "P1 (on ALT)goes to my ACC(on IGN SW)"..... this is the same thing as idiot light or your pushbutton EXCITE switch. This is suppost to make your tractor engine "turn off" (which is what you are complaining about) when you turn your key OFF. So based upon what you write, I'd suggest the following changes: 1) connect P-2 directly by short wire to alternator BATT STUD 2) connect alternator BATT STUD to starter solenoid BATT STUD (now battery will charge) 3) connect ignition switch BATT to starter solenoid BATT STUD, this will give power to BOTH the ignition coil and to P-1 EXCITE thru the ACC terminal 4) connect ignition switch IGN to 12 volt ignition coil input. You may find your "non-tractor standard" automotive ignition switch is "fried" inside. Just replace it with same kind of switch..... ....HTH, Dell
