BLOWN HEAD GASKET?
RON (GA)
08-10-2003 04:26:13
My '52 N overheated while mowing a week ago, now there is oil in the radiator. There also seems to be a loss of power. I believe this would indicate a blown head gasket, but wanted to ask here to be sure. If that is the problem, should I have the head milled prior to re-installing it? Any other suggestions as to what should be done while the head is removed? Thanks in adavance, RON.
Dell (WA)
08-10-2003 18:49:00
 Re: BLOWN HEAD GASKET? in reply to RON (GA), 08-10-2003 04:26:13
Ron..... ....what Salmoneye sez..... .and.....
before you pull ANY cylinder head, ALWAYS check the compression. Compression gauges $10+ (cheap). Compression reading will tell you if you have a blown headgasket. But combustion by-products (oily film on radiator water) is pretty good indicator of blown headgasket..... ....Dell
RON (GA)
08-11-2003 04:40:02
 Re: Re: BLOWN HEAD GASKET? in reply to Dell (WA), 08-10-2003 18:49:00
Thanks Salmoneye and Dell for the info....will keep you posted on the results....RON
Salmoneye
08-10-2003 04:28:46
Try a new metal gasket without milling first...Torque in the correct pattern as per FO-4 manual and then retorque after a few hours run time...
Some people have reported that after milling the valvs can hit the head...The small flat head should come back to 'true' if torqued correctly...
