primer?
Pete--NY
08-10-2003 17:53:18
I'm about ready to paint my 9n. It is down to bare metal and clean. Do I need a primer on the cast iron? I've gone through the archives and find conflicting opinions. I'm using good old oil base industrial enamel.
Thanks as usual. Pete-NY
LarryNAA
08-11-2003 10:31:48
 Re: primer? in reply to Pete--NY, 08-10-2003 17:53:18
Here is some Conflicting Input:
I primed my NAA, but now I wish I had not. I used Grey epoxy primer. Two things went wrong:
1) I didn't over-coat the epoxy primer fast enough, and instead, I let it set up hard. Then it's very difficult to get the color-coat to stick.
2) My tractor is a Red Belly, so every scratch on it reveals the grey primer.
So If I did it again, I'd either use no primer on the red parts, or I'd try to find red primer.
I also strongly recommend that you etch the bare metal before painting. NAPA sells somethiong called Tech Etch (or Tri Etch?). Very easy to use: Just spray it on clean bare metal, let it dry, and the paint really digs in and sticks hard.
Mike
08-10-2003 18:51:57
Pete,
As Mike OH said, you're going to get conflicting advice. If I take things to bare metal, anymore I just use the color enamel I want, it seems to last as good or better than with primer for me. Good luck.
Mike
Mike OH
08-10-2003 18:25:02
Pete- You'll get conflicting opinions on this. Many say it is not necessary; some say prime. When I painted my 8N, I pressure washed the entire tractor twice, using a degreasing product. I found out that the casting was red in color and not brown as I thought. I then wire brushed, sanded, and scraped, until most of the paint and rust was gone. I then washed it off with mineral spirits, then soap and water. After it dried, I primed all the sheet metal and topped with several coats of red. Oh yeah, I didn't use a spray gun, I used the expensive approach - spray cans. It worked for me.
