Order Ford 8N Parts Online
8N power take off lever
RJ
08-11-2003 10:20:14
I have 52 8N and the hydraulics as well as the power take off has worked fine. All of a sudden I cannot get the power take off to engage. The shaft itself sort of moves back and forth with the movement of the lever. Anyone have any info or advice as to what is going on?
'Ole Henry' (Va)
08-11-2003 17:16:02
 Re: 8N power take off lever in reply to RJ, 08-11-2003 10:20:14
The plate (and shaft) is removable, just remove the bolts and pull off. I've forgotten exactly, but I think the end of the shaft has a fork that fits onto a shift rail inside. You will be able to see once the plate is off.
With the plate off, check to see that the fork is ok, and that the rail will move. Be sure to align the fork and grove in the shift rail when replacing the plate. Not difficult as I remember.
John A
