Broken Manifold Stud
Ron - TX
08-11-2003 19:00:43
Had to replace my intake/exhaust manifold. Broke off two bolts. Drilled the first one out ok, but the second was a big problem. Rethreaded the holes, put in all new studs, now the second one leaks water when pressure builds up. What is the best way to fix this? Can it be fix without welding the stud? Will a helicoil work? Thanks in advance for all your suggestions.
Ron - TX
NO HELICOIL . . . Dell (W
08-11-2003 22:41:22
 Re: Broken Manifold Stud in reply to Ron - TX, 08-11-2003 19:00:43
Ron..... ...NO HELICOIL..... .there ain't enuff meat in side of block to holditt and besides unless you pucky them, they leak.
BUT..... ..do you know that you can re-tap your leaky 7/16" block for 1/2" stud instead? Then drill out your manifold for that particular stud.
OR..... .you could use stud pucky.
Remember, install your manifold studs 54 ft/lbs..... BUT..... .your brass manifold NUTS 27 ft/lbs, understand?..... ....respectfully, Dell
DON'T USE HELICOIL!!!!!
08-12-2003 10:14:24
 Re: Re: Broken Manifold Stud in reply to NO HELICOIL . . . Dell (W, 08-11-2003 22:41:22
I hate when disagreement happens, but I don't want you to make a costly mistake because of bad advice. DON'T use a helicoil in your block. The correct repair is to go to the next size larger stud. Be sure to use a brass nut. I have worked in a motor rebuild shop for many years and have had to fix too many blocks that were incorrectly repaired with a helicoil.
Rob
08-12-2003 04:36:11
What do you mean a helicoil wont work? A helicoil will work just fine there. I've done one with a helicoil and it works great! You dont know what you are talking about.
Rob
08-12-2003 11:15:32
 Re: Re: Re: Broken Manifold Stud in reply to Rob, 08-12-2003 04:36:11
I bet you never used a helicoil there. Sounds like bad advise.
Fast Ed Ohio
08-11-2003 22:37:30
You might try using a good quality pipe dope compound on the threads ( plumbers type ) My second choice a can of stopleak in the old radiator .
Ron
08-11-2003 22:16:33
Not an uncommon problem. Two fixes: Remove stud, coat threads with good sticky gasket cement (not silicone sealer). More common fix is put some good cooling system sealer in radiator (Lumiseal is real good). Same condition can arrise when replacing head bolts, same fix.
