oil pressure
redd
08-14-2003 21:19:33
Can someone tell me what the running oil pressure is on my 48 8N. how much should the pressure change during operation.
thanks Redd
redd
08-15-2003 22:22:52
 Re: oil pressure in reply to redd, 08-14-2003 21:19:33
Thanks for the info. I was concerned that my pressure was to low. It runs pretty close to what ya'll have said. Thanks, Redd
Brian-2N
08-15-2003 13:40:15
Redd,
The 8N users manual says 27 PSI at normal operating temperature at 1/2 throttle. It also says it will be high at start, and will of course decrease as speed is decreased.
Rick H. Ga.
08-15-2003 05:14:26
I Redd,
Actually, this is a frequently asked question on the forum and the responses vary. If you can search the archives (just type in "oil pressure") you will find a multitude on info.
My 49 8N starts at 40# cold then 20# hot on a 90* F day and about 5# hot idle. I have read that any oil pressure at all on these old N's is good. I have also read that some would think my oil pressure stinks. My N runs quiet and smooth at this pressure and should for a long time. HTH. Rick H. GA.
Jerry (AL)
08-15-2003 06:50:06
 Re: Re: oil pressure in reply to Rick H. Ga., 08-15-2003 05:14:26
You quoted my numbers on my 49 to the letter.
thats psi . . . Dell (WA)
08-15-2003 07:12:23
 Re: Re: Re: oil pressure in reply to Jerry (AL), 08-15-2003 06:50:06
Jerry..... ....couldn't resist, I'd compare oil pressure in psi not letters (grin)..... ..Dell
Bill
08-15-2003 08:18:39
 Re: Re: Re: Re: oil pressure in reply to thats psi . . . Dell (WA), 08-15-2003 07:12:23
Cold start my '41 9N has 20# it maintains 20# usually but when hot and after brush hoging for 3 hours it drops to 10 to 8#. Still runs good and still has power at that reading too.
Bill
