9 N worth the Money?
Robbie
08-15-2003 03:08:16
Hi Guys, I'm new to the tractor scene. A buddy of mine offered to sell me his 9 N for $1500 includes KK 5' brush hog, push blade and hay spike. The tractor starts easily, runs smoothly. Has a few agro-engineered quick fixes such as a clamp on a broken throttle rod, a leaky sediment bowl and a generator that won't recharge the battery. Oh yeah, and he threw a rod last year and had to have nearly everything in the engine replaced and welded up. I planned to push some snow and plow a garden, maybe mow the yard. I may want to use it as a trade in. Any thoughts on relative value? thanks.
scrub
08-16-2003 02:01:55
 Re: 9 N worth the Money? in reply to Robbie, 08-15-2003 03:08:16
If you are at least fair with a wrench it is a good price. If your not he could give it to you and you would lose money in the long run.
Bob - MI
08-15-2003 06:44:17
It would bring that easily without the impliments here in West Michigan. Don't plan on lifting round bales with that spike. The lift was never engineered for a load like that. You may want to make sure the 3-point operates properly before you sign off. A new pump and/or other internal hydraulic parts can get pricey especially if you aren't doing the wrenching yourself.
Good luck
Rob N Va
08-15-2003 04:44:34
Offer him 1400, and if he bites, take the hundred you saved and fix the sediment bowl and get the generator overhauled. That's just what I'd do.
I think the biggest question is how badly was the block damages when it threw a rod? How well was it welded? All things said and done, that's still a good price!---Rob
Tom
08-15-2003 03:54:31
Sounds like a pretty good price.My experience is in this area at auction they bring more than that without any implements.Good luck
Tom
tom t.
08-15-2003 21:31:42
 Re: Re: 9 N worth the Money? in reply to Tom , 08-15-2003 03:54:31
Robbie.
Think about it this way.
If you went and bought a new riding mower for 1400 or 1500 $, what is it going to be worth in 5 or 10 years; not much.
You could buy the 9n tractor and do about 399 other things besides mowing. dig a basement, or pond. blade the driveway snow removal too.plow a garden, or a 40 acre field. how about planting corn? or lifting heavy loads with the 3pt lift.
After you`ve done all that, you still have a good tractor that you`ll be able to get your money back out of 20 years later!
Now, does`nt that make the 9n a real bargain?
Tom T.
