naa side engine plate
randee peel
08-17-2003 12:14:18
On the distributor side of the engine just above the distributor there is a 4" by 20" side plate with a gasket that is leaking oil. Does anybody know what the purpose of this plate is? Is there anything ususual about changing this gasket? Just looks like three bolts.
Thanks
PDB
08-17-2003 19:48:27
 Re: naa side engine plate in reply to randee peel, 08-17-2003 12:14:18
Behind the plate are the pushrods and an oil tube that feeds the rockershaft.
Scott
08-17-2003 13:31:22
You should replace the seal washers on the 3 studs also and do not overtighten.
J52J
08-17-2003 13:12:48
nothing to worry about take the two nuts off and change the gasket, and put them back on. There's nothing going to jump out.
J52J/Jess
