Hobo, I got lost just after parking my truck next to the tractor, so bear with me and see if I can find my way. If I understand you correctly, we are about to perform a direct "High Voltage Electron Transfer Infusion" from a sparkplug lead of my truck's distributor cap (the donor), directly into the coil high voltage input to my tractor's distributor cap (the receptor). Thus we'll be relying on my tractor's rotor to time the incoming high voltage electrons to the needs of the tractors engine. Now if I goose the truck to about 4000 rpm, beings as how it is an eight cylinder, that spark plug lead is providing about 250 sparks per minute (SPM). Meanwhile my tractor at 400 rpm, requires 200 SPM( sparks per minute ) timed to the points opening and spark directed to the proper spark plug by the rotor, in order to bang all four cylinders. Now knowing from past practical experience my tractor will actually run on any two of the four cylinders, at 400 rpm. I actually require 100 SPM successfully delivered to a random selection of the four cylinders, as determined by the rotor. Therefore I will only require two of every five High Voltage Electron Infusions to the tractor's distributor, be successfully routed by the rotor to spark plugs in the tractor, in order to maintain a rough 400 rpm. Now for the really hard dart,,, At this point I'm standing there holding the tractor coil's High voltage lead in my left hand, sparking at 200 SPM. In my right hand I'm holding the truck's sparkplug High Voltage extension lead, sparking at 250 SPM. The tractor is running, although rough, at ~400 rpm. So I’m supposed to remove the truck’s donor High Voltage lead from the tractor’s distributor cap and replace it with the tractor’s original coil High Voltage lead , before the tractor dies? It sounds to me like I should dance in the snake pit at a Texas Rattlesnake Roundup. Have you actually tried this before? Am I going to get my butt knocked into the dust of tomorrow? What ever posessed you to conceive such a thought? Let me know if I have this correct. Thanks, ATW/WA
