i would really like to know what is lifting capaci
allan b.
08-22-2003 00:52:27
i know we should baby our old tractors, and i certainly know my 9n is not a bulldozer. but would you plz let me know now much you are lifting with your three point hitchs. 9n-2n-8ns only need reply. i have asked dealers. there are no specs i can find. can you overload them, or are there safety valves to protect them. any or all infor on this subject will help.
allan b.
08-23-2003 00:32:17
 Re: i would really like to know what is lifting ca in reply to allan b., 08-22-2003 00:52:27
thank you for your feed-back again. i dont want to blow anything out in the hydraulics. like mine now. sometime it will lift with ease, other time, i have to let it all the way down and then it will lift nice. its kind of sporatic. i sometimes have to add a little extra oil , then i lifts with new youth. i quess the main thing i have learned is just dont over-load it. just load what it will raise easily, and settle for that. otherwise , get it checked out. allan b.
Fast Ed Ohio
08-22-2003 23:36:06
Well, 500 to 750 lbs would be my guess at an old 8n, others claim a lot more , the relief valve will give if you have much more, wont hurt a thing, spring relief valve just returns to normal on its own .
dave 50 8n
08-22-2003 13:48:30
..about 1/2 load of rocks in my scoop
bg
08-22-2003 06:31:10
The official 2N service manual lists the weight of a 7' disk-harrow at 975 lbs. I assume that the 2N must be able to lift this much, or they would not have it included it. If you use front weights, it may increase the capacity some. I think llamas did a test where he lifted 1200 lbs with his.
'Ole Henry' (Va)
08-22-2003 05:21:56
Plowman is correct, about 6 to 8 hundred pounds, anymore and the front end is gonna be coming off the ground.
Pretty good indicator for me.....John A
PloughNman
08-22-2003 04:01:00
Hey Allan-
Go to the top of this page and click on ARCHIVES; type in LIFT in dialog box labeled keyword search and you'll get over 8000 reponses to this question. It seems the N's lift capacity is around 750-800 lbs. After that, you'll be popping your relief valve and have a real repair job on your hands.
Tim
