Order Ford 8N Parts Online
8N grill question
Rick
08-25-2003 16:33:55
Can someone show me what the 2 pins that stick out the top of the grill look like and their diameter and length. Mine are worn and broken. A close up picture would be great. Also, what size are the holes in the hood that receive these pins?
Buckeye Fan
08-25-2003 18:06:58
 Re: 8N grill question in reply to Rick, 08-25-2003 16:33:55
Rick, don't know if you have a 9n, 2n or 8 n. The 9 and 2 have a pin about 1/8th " in diameter and about 1/2" long, there should be three of them. The 8n has a spring type pin on each side to allow you to lower the grill to clean the chaff out of the radiator. Hope this helps. As Dell would say, " I flunked mind reading 101 " Respectfully, Buckeye. Hope this helps.
Buckeye Fan
08-25-2003 18:11:23
 Re: Re: 8N grill question in reply to Buckeye Fan, 08-25-2003 18:06:58
Rick, sorry I didn't read your post close enough, I apolagize. The holes in the hood will be slightly larger than 1/8".Maybey 3/16th. I could be wrong, I have been before. Buckeye.
size of spring type pin?
08-25-2003 20:19:21
 Re: Re: Re: 8N grill question in reply to Buckeye Fan, 08-25-2003 18:11:23
there are only 2 pins, one on each side. this is the spring type you mention. what is the diameter of the pins?
