Order Ford 8N Parts Online
Thermostat In 8N
PloughNman
08-25-2003 19:47:14
Hey Gang-
How many of you run your N-Series with a thermostat? How many run without, and why? I don't see any reason to use one, personally.
Tim
Evil Steve
08-26-2003 08:07:39
 Re: Thermostat In 8N in reply to PloughNman, 08-25-2003 19:47:14
bg said it the way it is. Yep, you can get away without one, but why would you wanna?
George Willer
08-26-2003 10:39:43
 Re: Re: Thermostat In 8N in reply to Evil Steve, 08-26-2003 08:07:39
I can think of two reasons...
1. Lack of understanding of the benefits of keeping the engine at constant temperature. (reduced wear, and increased economy)
2. Not wishing to turn it over to the next owner in good condition.
George Willer
bg
08-26-2003 03:57:49
You have to run a thermostat so that the heater will work in cold weather.....
Seriously, the thermostat keeps the engine in a more consistent heat range. This translates to better combustion, less plug fouling. The N cooling system is over-sized. if you have overheating problems it's more likely because the radiator or block is clogged.
