can you tell me what type of tractor i have
roger
08-26-2003 17:19:59
the best i can make of the numbers are ( AA81052 then a diamond symbol). in front of the cowling it has a cornstalk in chrome round bezel.gas engine. the reason i am asking is it was my dads and now i have it, was doing some bushing this evening and seen the oil pressure drop a little. when i got off it had a good leak of oil coming from the rear, like a rear seal is leaking.thanks..
david
08-27-2003 09:09:30
 Re: can you tell me what type of tractor i have in reply to roger, 08-26-2003 17:19:59
You have a 1954 NAA. Use a soft wire brush to clean the area further of paint, gear, oil, etc., then use a light or lamp on the area from different angles and you will find the "N" stamped before the AA. DO NOT USE SANDPAPER. Also you will find the other diamond once you find the "N".
Good luck. David
KC (Alaska)
08-26-2003 20:17:57
Roger see if this helps.
Scott
08-26-2003 18:21:32
If it has stars around the front hood emblem you have a 1954 model NAA and if you look hard maybe you can see a diamond and a N in front of what you already found.
