starter bolts question
Pat
08-27-2003 10:08:48
I am getting ready to rebuild the starter on my 51 8n. I have read to put nuts on the starter bolts to hold it together while removing it from the engine. They look like 5/16 bolts. Question is, what is the treads size. 5/16 by 18 or 5/16 by 20? would like to have them in my hand before pulling the starter. Thanks for the help.
PloughNman
08-27-2003 12:58:42
 Re: starter bolts question in reply to Pat, 08-27-2003 10:08:48
Hey Pat-
Yes, 5/16-18 coarse thread bolts (screws?) for the starter. Anything screwed into cast iron is going to be a coarse thread. It's an engineering thing because of the grain structure of cast iron, coarse threads do not strip out as easy, where fine threads would in cast iron. You'll find that the nuts and mating bolts were fine thread (i.e. 5/16-24; 7/16-20; 1/2-20; 5/8-18...etc.) because they are each made of steel, which has a different grain structure. Anyway, always be sure to start a nut or bolt by hand first to prevent cross-threading. If it won't start by hand, the threads are boogered up or dirty or both. Run a tap into bolt holes to clean them up or chase a bolt with a thread die to clean up old paint, dirt, grease, peened thread, or whatever. Nothing worse than being held up because you got a bad thread. HTH
Tim
Steve(OR)
08-27-2003 13:50:37
 Re: Re: starter bolts question in reply to PloughNman, 08-27-2003 12:58:42
Hmm... Coarse threads only into cast iron. That's my one new thing to learn today. Thanks!
Dell (WA)
08-27-2003 11:14:01
Pat..... ...unlike most of the N-Bolts, the N-Starter bolt is 5/16 COARSE THREAD. But like EvilSteve said, just pull one starter bolt and find the nut size that fits. And BTW Ford calls it a "screw" for some reason 7.18 long..... .Dell
don b
08-27-2003 12:09:43
 Re: Re: starter bolts question in reply to Dell (WA), 08-27-2003 11:14:01
Dell, if you price the new bolts at N/H,you will see why they call them "screws". don b
That would make... Evil S
08-27-2003 12:13:46
 Re: Re: Re: starter bolts question in reply to don b, 08-27-2003 12:09:43
... EVERY part they sell a "screw." LOL
Jim Cox
08-27-2003 11:08:35
the ford thru-bolt:
1811091 THRU BOLT 5/16-18x7-1/4.
Put a nut on each after you rebuild it, torque to 8-10 ft pounds, and test with a set of jumper cables. touch the hot cable to a 5/16-24 nut on the starter post so you don't damage the copper threads. You can take the nuts off the thru bolts after you have SEEN it run.
Good luck, and don't be afraid to try a local rebuilder or the New Holland 8N11001R
Jim Cox
Starter rebuilder guy
Steve(OR)
08-27-2003 10:41:41
I didn't think 5/16-20 was a standard size. I believe 5/16-18 would be a coarse thread and 5/16-24 would be a fine thread. There is a metric size that can be mistaken for 5/16-20. I know because I made that mistake at the hardware store last week. Somebody stocked the standard bin with metric bolts and they were very similar.
Rick H. Ga.
08-27-2003 10:34:50
Hi Pat,
I'm not sure about the #18 or #20 on the threads of the starter bolts. Several years ago, I needed the two long starter bolts for my 49 8N. Couldn't find exactly what I needed so I finally bought some 5/16 threaded rod and cut it to the right length x 2. I put two nuts on the end of each and it has worked like a charm for over 20 years. The threaded rod was the same size threads as the old starter bolts. HTH. Rick H. Ga.
Evil Steve
08-27-2003 10:34:08
Pat-
I don't know but you can just take ONE out and size it.
