Order Ford 8N Parts Online
8n grill pin diameter HELP
Rick
08-28-2003 16:49:39
I need to know the diameter of the pins that stick out of the top of the 8N grill and fit into the hood. Mine are broken/worn.
Gary T
08-28-2003 17:32:26
 Re: 8n grill pin diameter HELP in reply to Rick, 08-28-2003 16:49:39
I made a trip to the barn just for you :) Mine is .320. If you add a coat of paint to a 5/16 pin that should come pretty close. Hope this helps and the best to you>
and the hole? Rick
08-28-2003 17:45:56
 Re: Re: 8n grill pin diameter HELP in reply to Gary T, 08-28-2003 17:32:26
I really appreciate the help. And I assume the pins fit into a hole of the same size in the hood. Right?
