Log Splitter
Rotten
08-29-2003 05:58:58
I have a 2N with a dearborn loader and vickers external pump. I would like to find a log splitter that I could mount on the forks and use the existing hydraulics. Any input is appreciated,thanks.
Ron from IL
08-29-2003 07:45:00
 Re: Log Splitter in reply to Rotten, 08-29-2003 05:58:58
Rot,
If it were me, I'd look for a separate, self-powered log splitter. The hassles of hooking up a splitter to the tractor and the fact that it would then be dedicated to the splitter (rather than being able to use the tractor to help move the logs around, haul the splits, etc.) would outweigh the benefits, I think, of an attached unit. I have a chipper/shredder that mounts to the 3-point, and while it works O.K., if I had it to do again, I'd opt for a self-powered unit just for the versatility.
JMHO
Good luck!
Ron
Nut in NC
08-29-2003 13:21:25
 Re: Re: Log Splitter in reply to Ron from IL, 08-29-2003 07:45:00
I agree. I use my loader to pick up those logs that my back just can't handle and roll onto the splitter. Used to cut and split over 10 cords when I lived in Pennsylvania and used about every splitter. Find the horizontal is easiest on the back. Plus, a good freind of mine tore up his tractor pump with splitting logs.
