dearborn plow
Putz
08-29-2003 14:19:02
just bought a dearborn plow for my 52 8N. The model is 10- and the rest I can't make out. How do I tell if this is a 12" or 14" plow.Where do i measure ? Are parts available. Also the coulters are two different kind, is that right ? Thanks
Ultradog
08-30-2003 04:57:40
 Re: dearborn plow in reply to Putz, 08-29-2003 14:19:02
third party image
Try this:
Upper Peninsula, Mich
08-30-2003 13:33:07
 Re: Re: dearborn plow in reply to Ultradog, 08-30-2003 04:57:40
Hi Jerry. Where have you been all summer. Hear you have a new companion that is taking up more of your time. I'm in Lansing for the week. Nice to see you posting again. Talk with you later. Ron
Ultradog
08-30-2003 15:08:09
 Re: Re: Re: dearborn plow in reply to Upper Peninsula, Mich , 08-30-2003 13:33:07
Howdy Ron,
Shoot me an email. I lost all my addresses in a crash.
souNdguy
08-29-2003 21:25:18
third party image
Here is a picture of my 10-1..which I believe is a 14" plow
It is missing the front wheel/discs.
Soundguy
Fast Ed Ohio
08-29-2003 23:17:20
 Re: Re: dearborn plow in reply to souNdguy, 08-29-2003 21:25:18
I have a set of Dearborn 10- 1 plows that came with my 8n ( Im sure they are 14 inch ) .I removed the front wheel discs ( v shaped 2 in front of each plow , no way to get them set deep enough to cut soil) I also removed the tailwheel that was bent and caused a strong pull to the right, plows work great now when set properly .
GeorgeH
10-29-2003 09:49:17
 Re: Re: Re: dearborn plow in reply to Fast Ed Ohio, 08-29-2003 23:17:20
Do you still have the parts you removed and are they still servicable ?
PloughNman
08-29-2003 15:59:06
Hey Putz-
Can you post a picture or send me one? Dearborn designated ground breaking imnplements with the 10 prefix from the start, but the first models were 10-1; 10-8; etc. and later models (Economy Plow) were 10-152; 10-156; etc. One way to measure is across the frame beams from one side to the other, inside to outside. But, some farmers may have put a 14" moldboard and share on the rear of a 2-bottom 12" plow and kept the front at 12". Some new parts are available like moldboards and shares, shins, and landsides. Otherwise you're on your own for frame, rolling landside (furrow wheel); coulters; and jointers. The later Economy plows were better engineered. As far as the coulters being different, that really wouldn't matter that much as long as they were set properly. You may find, especially if they are old and dull, that they don't help cut very good so you're better off taking them off anyway. A wise old 8N man once said that they were only good for cutting snakes anyway. If you can't post a picture, contact me and I'll send you some pictures to help identify it. Hope this helps...
Tim
Lloyd
10-30-2003 10:08:56
 Re: Re: dearborn plow in reply to PloughNman, 08-29-2003 15:59:06
I have a model 10-10, I believe it says. I would like to advertise it for sale, however I was wondering what would be a fair price. Thanks.
Lloyd
