Carb Choke Spring Problem
Rick
09-01-2003 14:38:44
The choke spring in my rebuild kit is appears to be "backwards." It certainly does not match the old spring. When I put it on, the tension keeps the choke flap closed. There appears to be no way to use it so that the tension keeps the flap open. Is this correct - should the tension keep the flap closed? Thanks in advance.
Steve(OR)
09-01-2003 17:19:07
 Re: Carb Choke Spring Problem in reply to Rick, 09-01-2003 14:38:44
third party image
Tension keeps it open. Maybe this picture will help.
Steve(OR)
09-01-2003 17:31:37
 Re: Re: Carb Choke Spring Problem in reply to Steve(OR), 09-01-2003 17:19:07
...the round end of the spring goes over the little post next to the choke shaft. But just before you push it down all the way onto the post you will need to rotate the square end of the spring clockwise before you engage the arm on the shaft. You might need a small pair of pliers and an assistant if you don't have enough dexterity. Hope this helps.
Brian-2N
09-01-2003 16:27:17
Rick,
If you forgot how you took it apart (like I did), the picture in the FO-4 is of no value. The choke arm slides through the flap, The flap is on the top, and to the inside. The spring has two hooks. One catches over the arm, the other over the tab on the carburetor. Check your installation. HTH.
Rick
09-01-2003 17:34:57
 Re: Re: Carb Choke Spring Problem in reply to Brian-2N, 09-01-2003 16:27:17
Brian, thanks for the help. I'm ok with the flap now, but my new choke return spring is different from the old one. Are the replacements supposed to be different? Thanks.
Brian-2N
09-02-2003 05:02:00
 Re: Re: Re: Carb Choke Spring Problem in reply to Rick, 09-01-2003 17:34:57
I'm not aware that the springs are different today. My 2N didn't have one, and the one on my 8N was broken. That's a good picture in the above post. The spring holds it open. When you're holding the rod back, the plate is closed, but suction will open the flap.
