Carb--Dell?
49-8nMike
09-06-2003 13:53:28
Dell, the drain plug on the bottom of the carb on new tractor was epoxyed in due to being stripped out.
I had heard the tsx241 was a better carb than the tsx33. I'm going to have to get another carb and want your thoughts or opinion on them.
I can get either one for $50each. I have to rebuild them but thats not a problem. Ijust want the best carb.I did fuel systems work for 29Yrs.
and these are not a problem to work on.
Thank you for your time and help.
Dell (WA)
09-06-2003 14:19:52
 Re: Carb--Dell? in reply to 49-8nMike, 09-06-2003 13:53:28
Mike..... ...TSX-33, TSX-241-A,B,orC, they're all correctly sized for the 121 cu/in N-Tractor flathead engine. There's minor bleed orifice differences. The TSX-241B had an "economizer circuit" that didn't work as well as they wanted. The TSX-241C is probably the best but I wouldn't shop around for one special. They all work if rebuilt properly..... ....Dell
Gaspump
09-06-2003 14:14:50
Seems Dell is not at home but I can offer some assistance. The TSX33 is a fine carb with three jets and very well built. The TSX-241A, TSX-241B and TSX-241C were all later 8N carbs. The early 241's had two jets and the 241C went back to three jets. All will work great on any 9/2/8N. If You want quality go with either the 33 or 241B, 241A's were a problem carb and did not last long in production, the later 241C's (vintage 1952)were not so well machined nor were the castings as high quality as the earlier ones.
you're right . . . Dell (
09-06-2003 14:23:03
 Re: Re: Carb--Dell? in reply to Gaspump, 09-06-2003 14:14:50
Pumper..... ..I didn't check my carb notes, you're right, the TSX-241B is better..... ..Dell, who has CRS
