rear axle bolts broken
putz
09-06-2003 19:25:09
After finding out my rear rims are bad, I thought i would look at the brakes. Got the right drum off, still working on the left one.Two of the bolts that hold the bearing retainer onto the axle housing have the heads broken off inside by the brake shoes. Do these bolts have to come out from the brake side or will they come out from the outside if I keep turning the nut and pull them through ? If so can I get by with a plain bolt with a nut on the inside until I have more time to work on this ? I also noticed on the left side that two of those bolts are broken off on the outside. Been driving this tractor for almost 30 years , only a few minor problems, guess I owe it some repairs for all it has done for me !!
R.M. In AL.
09-07-2003 20:18:56
 Re: rear axle bolts broken in reply to putz, 09-06-2003 19:25:09
John is right : Look close at those bolts.I cant remember how many is in there but part of them screws into the hub from the outside and some have bolts going through from the inside with nuts on them>If you get any bolts that screw in from the outside into the hub, those are probably fine threads.I also suggest using some thread locker because mine had backed out over the years..HTH....R.M. In AL.
john
09-07-2003 07:37:33
Are you sure the bolts are broken off or do some thread in from the front and some from the back.
Steve IA
09-07-2003 03:41:51
If you get the nuts off, you can drive the bolts toward the shoes and replace them with standard machine bolts. IIRC, the originals have tapered splined shoulders to hold them tight when the nuts are tightened. I replace a couple of mine over the years. Steve 8N 169302
Fast Ed Ohio
09-06-2003 22:47:30
Sounds like you need a new hub.
Steve IA
09-07-2003 03:45:12
 Re: Re: rear axle bolts broken in reply to Fast Ed Ohio, 09-06-2003 22:47:30
How will a new hub help? Steve 8N 169302
Fast Ed Ohio
09-08-2003 23:45:13
 Re: Re: Re: rear axle bolts broken in reply to Steve IA, 09-07-2003 03:45:12
Yep, after 3 beers and 3 in the morning I was thinking bad hub nuts and studs . ( my mistake )
