Coil connections
Pete's '47
09-08-2003 16:14:59
Hello All, I'm putting a new 6 volt coil in my '52. The old connections are marked Battery and Distributor but the new one is marked Positive and Negative. I looked in the manual and the drawing shows the wiring to and from the coil but not what is + or -. Anyone know which should be Bat. and Dist.? Thanks in advance, Pete Rajek
Dell (WA)
09-08-2003 17:01:26
 Re: Coil connections in reply to Pete's '47, 09-08-2003 16:14:59
Pete..... ...this has been answered many times, you might want to consider checking the "archives" at the top of this great N-Board.
But for you special, the general rule of electronics is (+) to (+). Connect the (+) of the coil to the (+) of the battery. Since your battery should be (+) ground, that would mean that the coil (+) is connected to ground thru the distributor points.
It is important that your ignition coil be correctly connected polarity wize because you can loose upto 40% of your sparkies with incorrect coil polarity..... .....respectfully, Dell
'Ole Henry' (Va)
09-08-2003 16:41:13
Pete, your 52 8N SHOULD BE POSITIVE GROUND. If so, the wire from the battery goes to the (-), and the wire going to the distributor goes to the (+).
John A
Are you sure about that??
09-09-2003 09:21:13
 Re: Re: Coil connections in reply to 'Ole Henry' (Va), 09-08-2003 16:41:13
yes . . . Dell (WA)
09-09-2003 10:35:38
 Re: Re: Re: Coil connections in reply to Are you sure about that??, 09-09-2003 09:21:13
Ole Henry is correct..... ...The N-Tractor ORIGINALLY came from factory with the 6 volt battery (+) grounded. That means the battery (-) must go to the ignition switch. Then the igniton ON must go to the ignition coil (-). Just as the ignition coil (+) must go to (+) ground thru the ignition points..... ...Dell
