brake drum stuck
putz
09-14-2003 06:41:28
I,m still working on saving my original rear rims, so far so good. Having trouble getting the left rear brake drum off. Been soaking in liquid wrench and lightly tapping on for two weeks with no luck.The four slotted screws came out pretty easy,and I backed off the brake shoes. I need to get it off so I can see what's going on with two of rhe bolts that hold the bearing retainer on that are just barely sticking out with no nuts on them. How hard do I tap before I break something ? Anybody have any tricks ? Thanks?
Dell (WA)
09-14-2003 07:59:52
 Re: brake drum stuck in reply to putz, 09-14-2003 06:41:28
Putzie..... ...you gotts the hardpart done, the 4 brakedrum screws out. Its rusted at the axle hub. Bang on opposite sides with bigger hammer to get it to "rocky-rock"..... .....Dell
Tommy (TX)
09-14-2003 07:37:09
Putz, use a bigger hammer.(2lb'er)..Hit it around the edges to jar it loose...You'll have to hit it pretty hard...
Tommy
