Carburetor
Roger Groves
01-16-2001 14:12:17
I have a 9N Ford, I'm having trouble with the carburetor frosting up or icing over in cold weather when I run it. It has only half power and rpm even with the throttle full open. Does anyone know of a solution for this. I would like to be able to use the tractor in the cold here in Mo.
Thanks
Dell (WA)
01-16-2001 18:29:17
 Re: carburetor in reply to Roger Groves, 01-16-2001 14:12:17
Roger..... ...Most find a thermostat in the upper radiator hose prevents carburator frosting by keeping the engine block warmed up thus transfering heat to the manifold.
No law to keep you from blocking your radiator with some cardboard to cause the radiator to get hotter, might help.
You could also rig some sort of tin shield from the exhaust part of the manifold down to the carb to deflect heat onto the carb. Bailing wire it on, use a big #10 can.
Hope this helps..... ...Dell
Joel (SoCal 44's)
01-16-2001 14:43:51
Could keep her in the house ... Not sure of a known fix BUT there are carb heaters for aircraft. There ya have it....
Joel
