Can't adjust hydraulics
pat
09-15-2003 12:58:30
I have a 51 8n. The quadrant control lever only works the lift when the control lever is in the lower half of the quadrant. Anything past half way up and the lift goes all the way up to travel. I pulled the side cover and don't see any leaks. I tried adjusting the quadrant by loosening the four bolts. When I move the adjustment rearward, and put it in position control the lift won't come down far enough for the mower to touch the ground but draft seems to work. If I adjust the quadrant forward, the position control works ok, but draft control doesn't. Also, if I wiggle the position control lever just a little the lift moves. What shold I look for. Thanks for any suggestions.
ZANE
09-15-2003 18:43:20
 Re: Can't adjust hydraulics in reply to pat, 09-15-2003 12:58:30
You need one of my Jigs with instructions to adjust the lift properly.
See the link below for more information if interested.
Zane
