steering box shot?
anothertractor
09-16-2003 15:23:31
I am trying to prep up my new 8N and want to make sure it is right before I sell it. It seems that the front tires wobble while going at higher speeds. Will I need to replace the steering box or do all original ones have this to some degree. Can I find a used one reasonable. Can I just buy some gears from the Ford parts supplier in my town and fix it myself?
Thanks
souNdguy
09-17-2003 06:48:44
 Re: steering box shot? in reply to anothertractor, 09-16-2003 15:23:31
To add to what Jebb said.
The 9n/2n had the steering arms and sector gears together, and a gear at the end of the steering shaft.. turning the whel obviously turned one gear forward and one aft.
the early 8n improved on that a little with the ball-nut assemble.. but there was still limited adjustment. By rotating the side plates you could get some slack adjustment due to the eccentric housing, etc. ( FO-4 expalins this MUCH better than me )
The late 8n had a fairly decent scheme for sector gear backlash. There was a locking nut on a stud on either side of the gearbox, oposed from the steering sector. The stud has a slot for a flat head screwdriver... can be adjusted in or out ( may already be adjusted as much as it can.. who knows.. )
Best way to adjust is to jack up the front axle, and then adjust, and also check tie rod ends and steering arms for play, etc.. and lets you feel the movement in the spindles.
Replace / repair parts as necescary... Might be a good time to lube the steering box as well.
Late 8n had a cap screw or bolt on the right side. As dell would explain, look into the hood access panel, and look back down and under the oil pres gauge.. top right bolt/cap screw can be removed.. check it with a short wire.. but should be the one that isn't blind.. in other words you can add oil here... good 85/140 in the bottles with the small nipple work ok. I've used a short piece of vinal tubing to help also...
F0-4 has good pictures of disassembly, etc.
I rebuilt mine.. wasn't too bad for the actual work... just tedious removing hood, grill, dash, etc.. etc..
good luck
Soundguy
Jeb2N
09-16-2003 17:05:20
Kinda depends on what year 8N you have. If you have an earlier one, it actually has gear sectors built into the arms and is more expensive to work on than the later 8N which used a reciprocating ball screw. The later style has shims that you can add and adjustment screws so you can tighten up the steering box somewhat. Anyways, I would first examine the wheel bearings, spindle bushings, and drag link/tie rod ends before tearing into the steering box.
