NAA: hmmmm?? Carburetor maybe??
Roger
09-16-2003 15:53:05
I've replaced the sediment bowl assembly, new plugs,cleaned and gapped points, and the danged thing still won't start when the weather is cold. She fires once and dies and that's it until the weather warms up. Pretty weird. Maybe the carb needs a rebuild??? Help??? The weather is only going to get colder.
Louie Walker
09-17-2003 05:55:00
 Re: NAA: hmmmm?? Carburetor maybe?? in reply to Roger, 09-16-2003 15:53:05
Hi I had one that didn't choke enough in cold wheather The little spring on the choke butterfly was not strong enough I would take the breather pipe off and help choke by hand Hope this helps Louie
good answer . . . Dell
09-17-2003 06:20:42
 Re: Re: NAA: hmmmm?? Carburetor maybe?? in reply to Louie Walker, 09-17-2003 05:55:00
dang..... thats so obvious, good suggestion, check choke..... thanks, Dell
Fast Ed Ohio
09-17-2003 00:45:27
Roger, lets go with a NEW set of points and cond. and see what happens . ( wont hurt or cost much ).
ain'cher carb . . . Dell
09-16-2003 17:08:21
Roger..... ...lotta reasons why engines won't start cold but will when warm. Anything from weak sparkies to plain ol'tired engine.
I'd do a compression test first, Ford specs 90 psi min, dry then wet. 5 puffs min dry and ritter down. Then squirt of oil in sparkie hole and cranker'gain, 5 puffs min. Writter down. If you've got more than 20 psi difference between dry and wet, ya gotts a worn engine and if'n ya gotts less than 90 psi, you have a tired and worn engine that is canidate for overhaul.
One of the origial founders of this great N-Board used to claim, 80% of all carb problems were solved in the ignition system. I'd plan ahead and get the engine warmed up durning the day and while it was still warm, I'd starter up on a DARK NITE, and watch for little blue sparkies dancing on the sparkie wires and 5-nipple distributor cap..... ....Dell
Roger
09-16-2003 17:22:58
 Re: Re: NAA: hmmmm?? Carburetor maybe?? in reply to ain'cher carb . . . Dell , 09-16-2003 17:08:21
Dell...what's the purpose of doing the "start thing" in the dark??
Dell (WA)
09-16-2003 18:50:37
 Re: Re: Re: NAA: hmmmm?? Carburetor maybe?? in reply to Roger, 09-16-2003 17:22:58
Rodger..... ..."starter up on a DARK NITE, and watch for little blue sparkies dancing on the sparkie wires and 5-nipple distributor cap"..... .is an eazy way to check for bad sparkies. Which is symptomatic of your hard to start cold engine complaint. If you see little sparkies anywhere replace it..... ...Dell
SteveB(wi)
09-16-2003 20:34:55
 Re: Re: Re: Re: NAA: hmmmm?? Carburetor maybe?? in reply to Dell (WA), 09-16-2003 18:50:37
If you really want to bring'em out take a little spray mister bottle with water in it and give 'em a little shot.
