Rings or Valves
pj
09-16-2003 16:05:18
Can someone tell me if there is a way to tell if the oil that is fouling my spark plugs comes from the oil control rings or is leaking by the intake valves. I have minimal blowby but I continue to foul out #3 and #4 plugs. I have a '50 8n that had a valve job done by a reputible mechanic two years ago but I am wondering if maybe he left the O rings out of a couple of the lifters. The tractor has good power, has a little blue smoke when I gun the engine but hardly any when I am hogging with it, but it fouls the plugs on a regular basis. Any help will be appreciated.
thanks
ZANE
09-16-2003 19:16:44
 Re: Rings or Valves in reply to pj, 09-16-2003 16:05:18
Rings. Either the rings are worn or lost tension from overheating or the cylinder is work beyond specs.
Needs rebuilding.
Dell (WA)
09-16-2003 16:52:42
PJ..... ....since the 8N has a flathead engine, it is very difficult for engine oil to get sucked up the valve stem to foul your sparkies.
Best way to tell is a compression test dry then wet, 5 puffs min and writter down. The squirt in some oil (about 1 oz or 1 spoonful) and tester again. If'n ya gotts bad rings, wet compression will go up 20-30 psi over the dry reading. If'n ya gotts bad valves, compression won't hardly increase.
Recommend you use the hotter AutoLite AL-437 sparkies for better oil fouling resistance..... ....Dell
