First Apparent Error - Axle Trumpet Gasket Seepage
Rick
09-20-2003 17:16:19
I've been pretty lucky novice until now. Rebuilt the steering, trans, rearend, brakes, and axle - all seemed well. Unfortunately, even though the axle trumpets and center housing were "surgically clean" before placing the gasket and attaching the trumpets to the housing, I now have a slight seepage of 90 weight trans oil. Didn't use a sealer. I spoke to some folks at a highly regarded N parts and restoration company in Indiana and found they always use a light coating of sealer on the axle trumpet gasket. Ouch!! I'm not getting a lot of seepage - maybe the equivalent of a drop on the garage floor over a period of one week. Is anyone else getting that after a rebuild? I sure hate to take those axle trumpets off again!
Consider the possibility of using sealer.
ain'cher gasket . . . Del
09-20-2003 19:29:11
 Re: First Apparent Error - Axle Trumpet Gasket See in reply to Rick, 09-20-2003 17:16:19
Rick..... ...It probably isn't yer gasket, you did swipe it with warm water, didn't you?
Most likely, one of your trumpet studs turned a little loose and is leaking. The studs have a shoulder that is seated against the diffy housing but the stud hole is a thru hole into the oil chamber. If'n it ain't tight, gonnna leak. You only need to tighten up the bottom studs below oil level. Figger out a double nut arrangement (2-fine thread 7/16 thin jamb nuts will do). I'd do that before I'd pull the trumpet..... ..Dell
Rick
09-21-2003 05:26:32
 Re: Re: First Apparent Error - Axle Trumpet Gasket in reply to ain'cher gasket . . . Del, 09-20-2003 19:29:11
Dell, Thanks for the suggestion. Yep, I did swipe the gaskets with warm water. I'll check the studs today and let you know if it was the problem. Thanks again.
Rick
