Order Ford 8N Parts Online
Manual for 8N Frt. Mount Buck Rake
Roger
09-21-2003 06:47:57
I need a manual for this rake. It mounts in front of the tractor and is used to pick up the hay from rows and take to the barn. It works off the lift bars. We used it back in the 50's, but now I need help to attach it to the tractor. Help would be appreciated.
Dell (WA)
09-21-2003 09:24:05
 Re: Manual for 8N Frt. Mount Buck Rake in reply to Roger, 09-21-2003 06:47:57
Roger..... ...www.n-news.com "archives" lists a "Dearborn Lift Type Sweep Rake 14-21 (12 pgs)". All the other rake manuals are listed as side delivery rakes..... ....Dell
RJ-AZ
09-21-2003 17:30:50
 Re: Re: Manual for 8N Frt. Mount Buck Rake in reply to Dell (WA), 09-21-2003 09:24:05
My Grandpa had on in 1958 or so. I remember there were bananna shaped brackets that bolted to the lift arm and long rods for tilting the head back. It attatched way back under the tractor and had supprt loops that hung under the front axle. I was only ten at the time and was bucking hay into an overshot stacker with it.
Roger
09-22-2003 06:57:27
 Re: Re: Re: Manual for 8N Frt. Mount Buck Rake in reply to RJ-AZ, 09-21-2003 17:30:50
Thats the one for sure. I have all the parts. I will send for the information from N-News as suggested by Dell. Thanks to both of you.
Roger
