Tranny or rear end
Randy Steep
09-22-2003 21:03:42
Put tractor in 1st gear let out clutch and heard snapping noise , tractor will not move , tranny still shifts all gears , clutch seems to work , manually pushed tractor a few feet and tried it in gear , tractor did move , stopped and then it would not move again , any tips on what went wrong , maybe ring and pinion Thanks Randy
Tom T.
09-23-2003 21:51:15
 Re: Tranny or rear end in reply to Randy Steep, 09-22-2003 21:03:42
Randy,
I went through the same thing a few months ago. I split the 9n into between the engine and trans. the clutch was OK put it all back. then split trans off the differential.
It was the coupling [female on each end] that connects the trans to the pinion. you should be able to remove the round cover plate [w/dipstick] on the right side to look, and feel. its easy to fix after the split.
HTH Tom T.
Upper Peninsula,Mi
09-23-2003 07:33:05
Randy, all of what Bob said could be the problem. I did have a rear axle shaft brake several years ago and it acted exactly as you described. Moved the tractor a little and the rear wheel feel off. The shaft broke near the end. Good luck in solving this problem. Do you have a Sherman tranny. It could have slipped out of gear at the time you let the clutch out. Ron
Bob
09-22-2003 21:15:32
Ford 9N, 2N, or 8N, I presume?
Do your 3 point lift and PTO work? If they do, that would rule out a torn up clutch hub, or transmission input shaft problems.
Other possibilites... Broken splined coupling between transmission and differential bevel pinion... Broken bevel pinion or ring gear... Rivets holding ring gear to differential broken... Broken LH or RH axle shaft (or stripped splines on one of the the axle shafts)... Or...?
