Which Water Pump to get ?
Roland
09-24-2003 10:37:22
Fixing to change water pump on my 47 2n. Some parts stores tell me the pumps for 2n's and 8n's are the same, others say they are different. The FO4 showes different rebuild kits but I don't see any external difference. Will they interchange. Which one to get?
Thanks Roland
Fast Ed Ohio
09-24-2003 21:51:15
 Re: Which Water Pump to get ? in reply to Roland, 09-24-2003 10:37:22
Take your old one with you, thats what I did and got the right one the first time, they dont want the old one, for a core, they said just throw it away .
Jim/41_9N
09-24-2003 12:48:47
Been there, Done that.
I was sold the wrong water pump and was down for a weekend, until I drove 60 miles to get the correct one. There is one for 9N, 2N & early 8n. Up to 1948 I believe. This neck comes straight up out of the middle of the pump. See pic that follows.
third party image
Then there is another style for later 8N’s. This neck comes out the side of the pump. See pic that follows
third party image
Roland
09-25-2003 14:22:37
 Re: Re: Which Water Pump to get ? in reply to Jim/41_9N, 09-24-2003 12:48:47
Thanks guys. A NOVICE needs all the help he can get.
Gaspump
09-24-2003 16:59:20
I have 2 1951 8N's, 1 1952 8N, 1 1947 2N, two used and one brand new water pump in and around my shop and all 7 water pumps are the same! Can't see where anything else could be needed, also have checked 1940 repair manual and 1948 manual and all water pump intakes point the same direction. Are sure one of those pumps was not for the NAA and later engines?
souNdguy
09-24-2003 13:00:30
That must be to accomodate the distribuitor ,no?
Soundguy
Jim/41_9N
09-24-2003 13:10:56
 Re: Re: Re: Which Water Pump to get ? in reply to souNdguy, 09-24-2003 13:00:30
Not Sure. I have a 9N. When the pump is installed, the neck is pointing about 45-degree angle down, out towards the left side. The other style that I was sold, and was wrong for me, would have pointed out towards the right side (I think). There is a slightly different bolt pattern also.
Gaspump
09-24-2003 11:33:36
#8N-8501 listed for 9N, 9NAN, 2N, 2NAN, 8N & 8NAN 1939-1952.
souNdguy
09-24-2003 11:30:36
This is just a WAG.. as I don't have an f0-4 or MPC in front of me.. but could it be that since the block for the 9/2/early 8n are nearly identical, and the block for the later 8n is slightyl differnt.. that that would be the difference for the water pump... the distribuitor setup that is...??
Again.. just a WAG...
Soundguy
don b
09-29-2003 13:10:32
 Re: Re: Which Water Pump to get ? in reply to souNdguy, 09-24-2003 11:30:36
One size fits all.The aftermarket ones come with the gen. belt adjusting brkt. that is used on the side mt. dists.but it doesn't hurt to leave the brkt. on for the frt. mt. dists. don
