Governor Rebuild
Rick
09-26-2003 17:10:31
I'm in the process of rebuilding my 8N governor. The two levers have a lot of play between them. I know the manual suggests wrapping a shim around the inner lever post if necessary, but the current bushing seems to be ok - there's not much slop around the inner lever itself. How do I eliminate the slop between the two levers? Thanks in advance!
Jim
09-26-2003 22:20:46
 Re: Governor Rebuild in reply to Rick, 09-26-2003 17:10:31
I don't know exactly how much slop you call sloppy.....but as long as the arms are not binding, the seal is functioning, and the spring linking the two arms is not too loose or pre-loaded you should be ok. My governor has a shim installed as well and still exhibits quite a bit of free motion on the housing but it works like a champ. By far and away the most important issue to address on the governor is the spacing that sets the amount of free travel of the steel ball bearings. Mine had been improperly set and the balls darn near separated the housing from its mounting plate by running a grove in the pewter or aluminum housing. As near as I can tell....only God actually knows how the governor really works.....so if all else fails.....pray!
