Centrifucal Advance -2 Questions
OK Doug
09-27-2003 13:05:29
I've performed the CCW-24 Deg. rotation check on my Cent. Adv. Assy, With the Distributor still installed and in the vise on the work bench, No Movement. With the shaft assy removed and holding the lower shaft I can get the weights to move by holding the Cam and rotating it CCW. Two question: Should the upper shaft rotate with the Cam( it doesn't)? Would one of you guys explain to me how the Shaft and Cent. Adv. Assy works. Thanks
