re ; oil for transmission/ hydraulic fluid
alaln b.
09-30-2003 23:29:59
my question has been asked many times with just as many answers. i have a "9N" ford tractor, 1940. can someone plz tell me what are the best fluids for the Ford 9N Transmission. the original owners manual specified only two. they were straight mineral oil ( S.A.E. 90 ) above freezing. and ( S.A.E. 80 ) for below freeing. what about a gl-1 90 weight in winter and a gl-1 140 weight in summer. also on this forum it talks about ford m4864 mild ep gear oil, which conforms to api gear oil of gl3. this has additives of sulphur and phosphorus, which make it a better lubricant for transmission and for bevel gears final drives, where there is high pressure sliding contact. EP has nothing to do with hydraulic pressure. i just want what work best in my tractor. i tried some trans/hydraulic fluid from hew holland. and that seems like it doesnt lift as well, and i have noise in the hydraulics since i changed, i did have the m2c134d, but i was thinking of going to the very original oils of m4864a which is sae 80 for winter , or m4864b sae 90 for summmer. i want something that lifts well and keeps the gears quiet. no guessing please.
FC
10-01-2003 12:00:14
 Re: re ; oil for transmission/ hydraulic fluid in reply to alaln b., 09-30-2003 23:29:59
Just my opinion, but go with the GL1 found at any local wal-mart---$20. I used another recommended oil from the local farm supply and it leaked out of every orifice, and started sticking my clutch due to leaking out the front seal of tranny. Changed it to the gl1 and it is back to the same old tractor again without severe leaks and sticking clutch. If your seals, etc are new you might be ok with the thinner oil, but I found that everything worked better using the GL1. I am sure it will be stiff come winter, but I'll deal with it or keep it in the basement when it has to start on extreme days.
kevin
10-01-2003 10:17:57
Another free observation- I use the Tractor Supply 90W stuff year round. I have run my 8N at well below zero left outside with no heaters or other starting cheats of any kind, though I need to let it warm up for a few minutes or suffer pretty slow action with the lift. I use 10w30 engine oil also.
fwiw
kevin
Jim(Ottawa)
10-01-2003 09:44:21
After reading all the archives and searching high and low I found Esso Marvelube Gear Oil GL1 80W90.
Check with your local Esso, Standard Oil or Mobil distributor. It's in their on-line product listing. Works fine in my 8N during the summer and I'll have to wait a couple of months to seehow it does in the winter
souNdguy
10-01-2003 05:44:31
As you've found out, there are pretty much only 2 oils reccomended ( above freezing )... the thinner 134d oil.. which is the current NH spec.. and the original 9owt mineral gear oil.
If yuo don't like the thinner one.. as you've indicated your lift performance suffers.. then the answer is obvious.. go to the thicker 90wt oil. As someone pointed out.. sometimes you can get the gl-1 90wt mineral oil at wallmart.. and you should also be able to get it at tractor supply co.. brand name is tarveler.. marked as 'ford 1939-1952'
good luck
Soundguy
I think I would forget about the 140wt stuff.
Salmoneye
10-01-2003 03:01:33
See the link below...
PS...
10-01-2003 03:34:52
 Re: Re: re ; oil for transmission/ hydraulic fluid in reply to Salmoneye, 10-01-2003 03:01:33
Straight 90 weight 'mineral oil' is available in 5 gallon pails at Wal-Mart here...Even says right on the label "For Use In Older Ford Tractors'...
Salmoneye
allan b.
10-01-2003 22:05:13
 Re: Re: Re: re ; oil for transmission/ hydraulic f in reply to PS..., 10-01-2003 03:34:52
thanks to all that wrote in. i was getting so many conflicting stories before. now that i have used the 9-n for the summer. and used the thinner universal tractor fluid, i was definately not satisfied with it. i do believe that the thicker gear oils will do better. although not too thick in the winter. i was using the tractor in 85-100% weather. thats when it needs the most help, its got to withstand heat and high pressure, thank-you all for your help and feed-back, i was thinking the same as what alot of you were. i dont want to wreck something that isnt. the seller says use one type of oil, another say use universal, another says use m2c134d in all n-seriers, but it is hard to come by, and i think a-little light. thanks for your help. next i have one more question.
