Smooth hub 9er
RICKWI
10-06-2003 15:13:16
Can't believe none of you guys bought this beauty, Has to be an early riser.
9n141
10-06-2003 20:02:36
 Re: Smooth hub 9er in reply to RICKWI, 10-06-2003 15:13:16
Are smooth hubs really that hard to find???? BURT.
Jeb2N
10-07-2003 03:33:38
 Re: Re: Smooth hub 9er in reply to 9n141, 10-06-2003 20:02:36
They're pretty hard to come by. Not impossible, but difficult. The problem was, that smooth rear hub was cast as a single piece and since it was so large, was prone to getting air pockets inside and cracking after some use. They were only used for the first two years if i'm not mistaken. On top of that, most of them were replaced with the later style riveted hub, and I think Ford had a warranty/recall on them. Occaisionally, you see one that has one smooth hub and one riveted hub, but that just looks goofy. Smooth hubs are now very desireable due to their rarity. Most end up as show tractors.
Scott
10-07-2003 05:17:27
 Re: Re: Re: Smooth hub 9er in reply to Jeb2N, 10-07-2003 03:33:38
They were not cast in 1 piece, they fused a alloy steel axle to a cast hub and that is what was weak, if the heat process was not correct it was weak from day 1, Ford did pay for them when they broke in the 40's, do not trust them, 1 just broke last year near me and it had been cracked for a very long time and was just holding by a 1/4" for who knows how long.
Jeb2N
10-07-2003 07:48:22
 Re: Re: Re: Re: Smooth hub 9er in reply to Scott, 10-07-2003 05:17:27
I was only referring to the casting as being one piece, not to include the axle itself. As you said, one cracked and had been cracked for a long time. That was the typical problem and accounts for so few of them being left intact today. Hence the increased collector value. Stay away from them if you want a work tractor, but collectors seek them out. I'm surprised that one on ebay didn't get bid on.
D. R. White MN
10-06-2003 15:48:18
Rick did you see at the top of the page why it ended. "The seller ended this listing early because of an error in the listing." Think maybe some one told him what just the axles are worth? Dave.
Rick(MN)
10-06-2003 19:40:41
 Re: Re: Smooth hub 9er in reply to D. R. White MN, 10-06-2003 15:48:18
What are the axles worth?
D. R. White MN
10-07-2003 11:06:48
 Re: Re: Re: Smooth hub 9er in reply to Rick(MN), 10-06-2003 19:40:41
Well up there in MN. the hubs will sell for $400.00 plus for one. Dave.
Jim.UT
10-06-2003 16:23:54
Very possible. If anyone is dying to have a smooth hub 9N, let me know. This one is sitting in a consignment yard at a local FNH dealer. The last time I asked, the price was $2500. I've not heard it run, but I could look into it closer. I'd be willing to broker the deal and store it at my place until you can come pick it up. Or I could just give you the phone number of the place where it's sitting. It has aluminum dash, steel hood, and a Sherman of some sort (either over or under...not a combo). Email me if interested.
third party image
