Order Ford 9N Parts Online
9N Snow Plow
Ron
10-07-2003 16:35:54
Will a 3 point hitch cable driven snow plow for a 9N fit an 8N?
Tom-Pa
10-10-2003 17:15:53
 Re: 9N Snow Plow in reply to Ron, 10-07-2003 16:35:54
only if it is the type that connects under the axles. If it goes back to a single point hook-up
then it will only fit the 8N as it has the bolt bosses for it. One the fits the 8N only will not fit the 9N/2N. My snowplow fits all 3 models as it attaches under the axles. I have to use the angle iron sway bar adapters tho...and drilled the appropiate hole larger...
good luck
RWK in WI
10-07-2003 17:57:18
Yes. The cable lift plow fit the 9N 2N and 8N tractors. Some even could be modified to fit the later 600 series. I hope this helps you.
Fast Ed Ohio
10-07-2003 22:05:36
 Re: Re: 9N Snow Plow in reply to RWK in WI, 10-07-2003 17:57:18
Make sure you get all the parts that go with it, I understand they are hard to find .
