1954 NAA reverse problem
Roger
10-09-2003 19:45:09
Hi guys,
Tranny has plenty of oil, clutch is adjusted correctly but I have a heck of a struggle getting the shifter into reverse or 3rd. Those 2 are just real stubborn. Somebody said somethin' once about a spring or bearing???? Can this be fixed in the home shop??
Help!!
jim
10-11-2003 23:08:19
 Re: 1954 NAA reverse problem in reply to Roger, 10-09-2003 19:45:09
The spring and detent ball is on the right side of transmission for the reverse gear.
Jim
jim
10-09-2003 20:40:20
Yes you should have no trouble fixing this problem.
There is a spring and 3/8 ball that rides in a detent and these (1 on each side of the transmission) can be loosened or cleaned/ inspected.
About to go to bed now but will take a look tommorrow and if you still haven't figured out they are behind a plug on each side of transmission. Maybe will send a picture.
Jim
