ford holley carb?
phillip
10-13-2003 17:42:04
I HAVE A PAIR OF 1 BARREL HOLLEY CARBS WITH A CLEAR GLASS FLOAT BOWL. I SAW A SIMILAR CARB LIKE THESE AT A LOCAL PULL ON AN 8N WITH AN STRAIGHT 6. ARE THESE CARBS WORTH ANYTHING? THEY ARE COMPLETE AND IN WORKING CONDITION. THANKS FOR ANY HELP.
Kens640
10-23-2003 19:05:37
 Re: ford holley carb? in reply to phillip, 10-13-2003 17:42:04
Hi Steve , can you send me pics of these carbs & info about their condition ? I have a 1952 8n Funk with the original Ford OHV 6cyl in it that I'm restoring . The original carb had the metal float bowl , which I don't have anymore due to sending it to a guy for possible repairs & not getting it back .Thanks , Ken
phillip
10-24-2003 02:14:01
 Re: Re: ford holley carb? in reply to Kens640, 10-23-2003 19:05:37
sorry, but i sold them last week.
phillip
10-14-2003 01:53:04
thank you for your help. the carb number on one of them is 18r1958.
Donzil (NM)
10-13-2003 21:33:03
Hello,
The initial 6 cyl Funk conversation kit for the N series used the Ford 226 industrial flathead six (some later versions used OHV 6 and V8 engines)which came with a one barrel Holley carb. These were solid metal bodies and did not have glass floats to my knowledge. My Funk six has a Chevy carb and runs great, but I am looking for an original. I am told some of the flathead sixs used were truck engines out of the F-1 trucks from around 48 to 50, so might be a carb from that type, however I have not seen any used on them. Having two just alike might be one barrel carbs from the small V-8 Flatheads, seems I recall seeing something about them using a pair of one barrel Holleys. Anyway that is what little I have gathered from owning a Funk 6 Ford 8N for a while. My information may be in error, so don't bet the gas money on it. Hope that helps. Donzil (NM)
Charles C(MO)
04-29-2004 11:05:13
 Re: Re: ford holley carb? in reply to Donzil (NM), 10-13-2003 21:33:03
Can you tell me the Make and Model number/part number of the carb on your Funk?
Thanks
Charles
Steve 40-45
10-13-2003 18:04:28
I seem to recall my 60 Falcon had a Holley 1bbl with a glass bowl. Other 6cyl Fords(early Mustangs)of that vintage also used the glass bowl. I have no idea of value today.
Steve 40-45
