So long as the carb has an embossed "Marvel Schebler" on the body, there is hope for getting it to idle without modifying it. The clone carbs don't have this logo visible. The best way to research the problem is to disconnect the governor arm and attach a spring to pull the throttle towards the closed position. Adjust the idle stop screw to a level that will allow the tractor to start and continue to run. (Your 600 RPM). Now slowly unscrew the idle stop screw. As the throttle blade is closed, the engine will slow down. If the idle system does not work, the engine will also start to falter. Try lightly seating the idle mixture screw. This takes the idle mixture as rich as it will get. Still no help? Do a thorough vacuum leak patrol. Any source of extra air (carb gasket, manifold gasket, intake valve guides, hole in manifold) will lean out the mixture and take the idle system outside of its tuning range. If you think you've eliminated any chance at a vacuum leak, try the following test. Remove the air cleaner pipe. Get the engine to the "begin to falter" point. Obtain an unlit propane torch. Crack the valve on the torch, and induce some propane into the air flow flowing into the choke horn. If the idle steadies out, you have verified that the mixture is too lean, because the carb isn't flowing enough fuel. If the idle does not improve, something else is wrong, like the ignition system. If propane helps, and you are SURE there are no vacuum leaks, you will have to open up the carb. Inspect for blockages in the idle passages. Perform the Zane polish-the-case-halves ritual. Check the float level. If nothing helps, you can consider carb mods. Buy yourself some idle jets and a set of numbered drill bits. Drill out the idle jet a few drill sizes and see if you can lower the RPM the tractor will operate at. This should allow more fuel to flow at low engine speeds, and bring the idle air bleed system back into its adjustment range. If you want to venture into really advanced carb theory, it is my opinion that the idle transfer passage in the Marvel Schebler is poorly located. It is possible to get a solid 400 RPM idle, and still have lean missfire in the 600 RPM range. The idle transfer passage is too far down in the throttle body, and doesn't kick in soon enough. You need at least a drillpress to consider this mod, however. Before investing all this time and effort, consider that the main reason for the 400 RPM idle spec is to allow the tractor to be started with a hand crank, and to cater to weak electrical systems in cold weather. It's kinda cool to hear the engine ticking over so slowly, but it really isn't necessary for day to day use of the tractor, assuming it starts easily.
