Hey guys!This is a follow-up to my post on 10/7. I was wondering why my '50 8N would run a stream of oil out the breather cap when it warmed up. It seems to get worse when the tractor goes UPHILL (I mistakenly said downhill in the post). I got replies from Dell and Fast Ed (who both thought it might be an overfilled crankcase) and Evil Steve (who thought it was a broken ring). Well, I bought a compression tester and ran the wet/dry tests on both my 8N and my 2N (with an early 8N motor) and here's what came up: 8N Cylinder Dry Wet 1 80 95 2 95 95 3 95 100 4 105 105 2N
Cylinder Dry Wet 1 80 95 2 95 105 3 97 100 4 85 90 In my infinite ignorance, I've come to the following conclusions: 1.) While the compression readings are somewhat low, I don't feel they indicate a broken ring(s). 2.) I'm baffled as to why the 8N blows oil out the breather when it has better compression readings than the 2N, which blows no oil at all. 3.) Also, even though the 2N's readings are lower, it seems to have more power, and runs smoother than the 8N. 4.) I also changed the oil and filter on each tractor. I only put in 5 quarts in each. The 8N (which I bush hogged with on Sunday for 2 hours) still insists on blowing out oil. 5.) Could the valves be at fault here? Help! I'm once again open to all comments/suggestions! TIA Ron
