found another gear oil
pat
10-14-2003 12:27:13
I did some research and found that pennzoil makes a 90 wt. mineral gear oil that will not harm yellow metal. I changed my gear oil in my 51 8n with this stuff and it works great. You can check it out at www.pennzoil.com it's called 409 mineral gear lube. It's worth reading. I would like to know what you guys think about this.
pat.
Jerry/MT
10-14-2003 21:22:06
 Re: found another gear oil in reply to pat, 10-14-2003 12:27:13
Pat, As long as it meets the -134 spec it's good to go.
Jim in Pa.
10-14-2003 15:51:00
since N trannys are non-syncro, I'd like to know if there's enough yellow metal in one to make this issue that important.
Got my 5 gal. of GL-1 at wallmart but haven't had time to do the brakes yet.
Sure seems like extreme pressure qualities would be desirable in a draft machine's gearboxes if they were at all compatible.
Duner Wi
10-14-2003 17:03:21
 Re: Re: found another gear oil in reply to Jim in Pa., 10-14-2003 15:51:00
I think the yellow metal in a 9n is in the hyd. pump.
Jay 2NSC
10-14-2003 14:22:36
Hi Pat,it's the GL-1,that is formerly none as 409 mineral oil.Kinda like the artist formerly none as Prince.Maybe they'll change back to?? ;>) Jay 2NSC
steve19438
10-14-2003 13:16:23
what did you pay for it?
steve19438
10-15-2003 08:59:59
 Re: Re: found another gear oil in reply to steve19438, 10-14-2003 13:16:23
i paid about the same at TSC.
pat
10-15-2003 08:45:18
The pennzoil 409 mineral gear oil was less than $30.00 including tax.
