distributor
Robert
10-16-2003 15:56:39
can someone tell me how to change out and replace front mount distrbutor?
Gary-Miss
10-16-2003 17:39:21
 Re: distributor in reply to Robert, 10-16-2003 15:56:39
It's pretty easy. Remove the coil from the top, then remove the distributor cap from the front. Note the general direction the rotor is pointed. Remove the distributor with a 3/8 short extension and a 1/2 socket. When you remove it, you will note that the drive is offset to one side so that you can't get it in wrong other than TRYING to put it in 180 degrees out. This is the reason for noting the rotor direction. Good luck.
Tweeter
10-17-2003 21:29:37
 Re: Re: distributor in reply to Gary-Miss, 10-16-2003 17:39:21
When removing the distributor, I found it easier to also remove the generator. For easy access. Make sure to clean the two 1/2" bolts well before reinstalling. They ground the distributor.
